- biggjcExplorerOk - thanks much for the suggestions. I have a message posted to Winnebago - in the meantime, I am going to attempt to remove the TV to gain visual access to the inside of the front cap. I suspect that something has come loose - and it is banging against the
Bottom of the front cap, which is right above the driver/passenger. I can accept that there will be rattles and squeaks, but this is especially loud, and since it is right above my head, especially annoying , Thanks again for your thoughtful responses! - RolinExplorerX2 on Cambria/Aspect Proboards.com.
I replaced the heavy tube type TV in our Aspect. I loosed the trim boards at the bottom, rotated them to access the screws. Then removed the molding around the TV, Then used a wrench to loosen the metal bracket that holds the TV in place. The hardest part is moving the TV enough so you can disconnect the power and antenna cable then lowering it to the dinette table. It was heavy. Ours is a 2007.
I did some insulating in the area behind the TV, dressed the cables and stuff so they would not rattle and built a enclosure for the area, then installed a new lighter TV and now have some extra storage I can access behind the TV. Pictures on the Cambria/Aspect proboards.
There could be some bolts in the area behind the TV that are loose and that is causing the rattling. In ours it was just cables and some zip ties and stuff fixed that. - BobboExplorer IIIThat is how I accessed the area behind the TV in my 07 Winnebago Outlook's cabover entertainment center.
- studies01ExplorerOn earlier year Aspects & Cambrias, one has to remove the TV to access the front area. This involved removing the wood molding strips that uncovered some hidden screw fasteners. Then the steel band could be accessed/loosened so that the TV could be pulled forward, wires disconnected & then removed. Not as hard as it sounds: the older TV's weighed a few pounds though!
- rvtenExplorer
- Kit_CarsonExplorerCall Winnebago with VIN # or Serial # and they will be able to tell you exactly. Very good customer service from these folks.
