- wa8yxmExplorer III
mowermech wrote:
In many states, 13' 6" is the maximum allowable height of any vehicle.
It is a pretty safe bet that your coach is 13' 6" or less.
Edit: Delete Many (In the phrase Many States) Replaced with ALL.
But that is correct
I like the idea of parking in a facility with a known height ceiling, Or parking under a tree limb or other overhang... Then measure the height to the bottom of the overhang (May be done after moving) and measure the clearance.
Option two. Take a laser level and a wall or other item (Post) at least 14 feet high. Pull out 14 feet of tape (or pull out 10 feet, maker a mark and pull out another four) and mount the thing to the wall/post (Tape works)
Using a laser level on top of the RV.. "Shoot" the tape.. Where the red dot strikes.. that's your height.
Option 3: NOT recommended.. When you drive under the 12 foot high bridge.. And your rig used to be 12'6" high. - 2oldmanExplorer II
All I could afford wrote:
LOL. Think OP's had enough? :)
You guys are making this way too complicated... - All_I_could_affExplorerYou guys are making this way too complicated...
1) measure from the ground to the bottom of the body
2) loan your RV to a teenage male
3) after he rolls it, simply measure the WIDTH of the RV
4) add both measurements to get the height - 2oldmanExplorer IIMeasure on the ground from RV to a point where the sun's shadow ends. Call that distance Y. Measure angle from that point to RV roof edge. X (height of RV) is given by: X/Y= tan (angle).
- SCVJeffExplorerYOURE THIS MANY
- D_E_BishopExplorerA variation on the 2x4 hanging over the edge and measuring to the ground. Measure to the top edge of the RV add this to a measurement from the top edge of the RV to the bottom of a piece of 1x2 or other light weight piece of lumber laid across the highest point on the roof.
It is easier than the one measurement method and only requires one person. I have a 4' yard stick(oxymoron) and it is adequate and weighs ounces instead of pounds. Mine was 11' 2" and so I quote 11' 6" when asked.
I tried to measure the difference between the heights with 80lbs tire pressure and 100lbs and that is not worth the effort. With airbags how much will they add between recommended pressure and max pressure. I could have added 6" but 11' 6" sounds better and more easily visualized than 11' 8", besides my DW can remember it. - WalabyExplorer IITake the square root of pi, multiplied by 2.6335, and add the air speed velocity of a swallow and you should be close.
Just don't ask if it's an English Swallow, or an African Swallow.
Mike - YajExplorer
Executive wrote:
I tried to measure mine using the Common Core method....using that method, mine came in at 62'!:E:E:E... Using a tape measure I came in at 13'1". I recommend the tape measure. I used a 6' level off the TV Dome as that's the highest point...Dennis
O-yah your going to hell now. "they" will see to it! - Executive45Explorer IIII tried to measure mine using the Common Core method....using that method, mine came in at 62'!:E:E:E... Using a tape measure I came in at 13'1". I recommend the tape measure. I used a 6' level off the TV Dome as that's the highest point...Dennis
- darsbenExplorer IIIf you are on 95 then do not worry you are shorter than the tractor trailers.
Not to many underpasses in Manhattan and you should not use the Holland Tunnel as it has a 12' 6" height/
The Lincoln tunnel is 13 feet
38,766 PostsLatest Activity: Jan 10, 2026
