- Deb_and_Ed_MExplorer II
IAMICHABOD wrote:
While like the others I don't stabilize my RV,just level it,it doesn't move much.
However while camping next to a rather Robust couple I saw that they used These placed under all 4 corners of the house part to keep it from rocking.
We used 2 of those at the rear frame corners just to take out the bit of bounce as our large dogs moved around at night. Worked great, and they're a cheap and compact solution - IAMICHABODExplorer IIWhile like the others I don't stabilize my RV,just level it,it doesn't move much.
However while camping next to a rather Robust couple I saw that they used These placed under all 4 corners of the house part to keep it from rocking. - DrewEExplorer IIFor leveling, I have a series of 2x ramps that I use as needed.
For stabilization, I haven't found I need to do anything special. There's not enough rocking in my RV to annoy me. Maybe that's not an answer you were looking for, but it's the only one I can give. - PghBobExplorerWe don't stabilize, but we do level the rig. Most often, for us, just being level is good enough for our 27 foot Class C.
- Dick_BExplorerJT Strongarm stabilizers. You might want to search this forum for `stabilize' to read previous posts. Lots of info.
To minimize the results search only in the Class C category. - donn0128Explorer IIMy fiver is 36 feet long. In order to help stabilize it, I first replaced the 10ga steel box the rear stabilizers were bolted to with more substantial pads. Then I added a second set of stabilizers just ahead of the axles. That took probsbly 90% of the movement out, and cost a lot less that JT strong arms.
38,748 PostsLatest Activity: Aug 23, 2025
