univmdExplorerNov 19, 2016How do you winterize water heater OUTput pipe?Winterizing: after draining & bypassing water heater, how do you get pink antifreeze to the water heater's output pipe which exits from the top of the now empty water heater? The water heater outp...Show More
GPWayneExplorerNov 19, 2016If you have used air to blow out the system before adding the pink stuff it's not a problem.
Related ContentWinterizing tankless water heaterAtwood water heater problemWinterized Water HeaterWinterizing tips and tricksGenerator output voltage
