valhalla360
Jan 04, 2023Navigator
RCMAN46 wrote:
The 220VAC is two phase power with each leg 180 degrees from each other.
Excellent visual for the lay person(even if there are some technicalities).
If you tie Phase 1 back to the common, you get 120v.
If you tie Phase 2 back to the common, you get 120v.
If you tie Phase 1 to Phase 2, you get 240v.
Generally in an RV, Phase 1 & 2 are only tied back to the common, so you wind up with 50amps @ 120v on each Phase (aka: Leg).
38,782 PostsLatest Activity: Sep 10, 2026
