gbopp
Aug 16, 2013Explorer
Again, welcome to the forum hounddogboy. Your second post is making more sense.
one option is to use the search block. Type in your question, 'plumbing', 'holding tanks', 'maintenance', etc..
If you can't find the answer to your question, just ask in a post.
The plumbing is pretty much what is used in a house, plastic pipes.
As mentioned before, it's not a septic tank. It's a holding tank.
There is usually one tank for black water (sewer) and gray water, (sink and showers).
You also have a fresh water tank.
Obviously, as you use water the fresh water tank will empty and the holding tanks will fill.
Adding fresh water and emptying the holding is a realtively simple process.
Do a lot of reading and ask questions, you'll learn quickly.
