hounddogboy
Aug 16, 2013Explorer
how does the plumbimg work in a rv?
allow me to clarify this better one last time.
and if that one ridiculous thread just below i made could be deleted?
anyway, i am now starting to look into buying my first rv.
what i would like are some tips on how to keep it maintained the easiest and most cost efficient way with the plumbing.
i am not sure if i will buy new, or used yet.
i would like to learn something off the net, before i go to a rv lot and talk to some salespeople. i don't know much at all about rv's, the most i have done is drive a u-haul truck.
i also plan to rent one first to learn about them, and see what that's like. but i want to avoid any problems with the plumbing in case i am stuck with no help somewhere strange and new.
do all rv's use a septic tank? or is there another alternative type system inside rv's these days?
do you handle the draining yourself? or are there places who provide that service?
how difficult is it would you say to drain yourself?
what kind of chemical brand names do you recommend? as i heard you need them.
how often would you estimate it be drained for 2 adults using the rv? or is there some kind of meter that tells you?
does the toilet, shower and sinks all drain into one tank?
i would like to know about as many con's as possible, and tips on how to avoid these con's of the plumbing.
that's all for now. i probably will have follow up questions.
thanks for any help.
