hounddogboy's avatar
hounddogboy
how does the plumbimg work in a rv?
allow me to clarify this better one last time.
and if that one ridiculous thread just below i made could be deleted?
anyway, i am now starting to look into buying my first rv.
what i would like are some tips on how to keep it maintained the easiest and most cost efficient way with the plumbing.
i am not sure if i will buy new, or used yet.
i would like to learn something off the net, before i go to a rv lot and talk to some salespeople. i don't know much at all about rv's, the most i have done is drive a u-haul truck.
i also plan to rent one first to learn about them, and see what that's like. but i want to avoid any problems with the plumbing in case i am stuck with no help somewhere strange and new.
do all rv's use a septic tank? or is there another alternative type system inside rv's these days?
do you handle the draining yourself? or are there places who provide that service?
how difficult is it would you say to drain yourself?
what kind of chemical brand names do you recommend? as i heard you need them.
how often would you estimate it be drained for 2 adults using the rv? or is there some kind of meter that tells you?
does the toilet, shower and sinks all drain into one tank?
i would like to know about as many con's as possible, and tips on how to avoid these con's of the plumbing.
that's all for now. i probably will have follow up questions.
thanks for any help.
  • Again, welcome to the forum hounddogboy. Your second post is making more sense.
    one option is to use the search block. Type in your question, 'plumbing', 'holding tanks', 'maintenance', etc..
    If you can't find the answer to your question, just ask in a post.
    The plumbing is pretty much what is used in a house, plastic pipes.
    As mentioned before, it's not a septic tank. It's a holding tank.
    There is usually one tank for black water (sewer) and gray water, (sink and showers).
    You also have a fresh water tank.
    Obviously, as you use water the fresh water tank will empty and the holding tanks will fill.
    Adding fresh water and emptying the holding is a realtively simple process.
    Do a lot of reading and ask questions, you'll learn quickly.
  • okhmbldr wrote:
    Watch the movie "RV" with Robin Williams. Pay close attention to the scene where he empties the holding tanks.
    My all time favorite scene in any movie!
  • Watch the movie "RV" with Robin Williams. Pay close attention to the scene where he empties the holding tanks.
  • Good info in the two posts above. First guy had it right and the second added info on dumping but failed to mention to rinse your hose well before storing or you may get odors. NO chemicals needed as its only a holding tank and if everything is working properly you will get no odors. One caviet is never flush the toilet while fan is running.
  • tkcas01 wrote:
    I don't think you need to be so concerned about the plumbing system vs other systems on an RV, but my thoughts below in red.
    It's not a septic system, but "holding tanks"
    Yes, folks typically "dump" their own rigs. I have seen some state parks that have a "pump out" service provider if their sites do not have sewer, but I have never seen a full-service RV dump station.
    As long as you have a quality hose with quality connectors, not a problem at all.
    If you flush your tanks properly after dumping, chemicals should not be required.
    It depends on the size of the holding tanks and your usage. For example, I have a 40 gallon "black" tank and 60 gallon "grey" tank. As a single person I can go a week or so before needing to dump with normal use. Of course if you want to dump less often, you can try to use less water. Yes, there are tank level sensors but due to build-up over time they seldom work properly.
    Toilets will always empty into a "black" tank. Typically all other drains (sink, lavs, showers) drain into a "grey" tank. Some manufacturers may have one of the lavs drain into the black tank. Some fifth wheel trailers may have two grey tanks - one near the kitchen, one near the bathroom.
    The main "con" is that the tank level sensors can be notoriously inaccurate due to build-up and such. Most people give up and can tell from the way toilets sound when they flush if the black tank is getting full. If the grey tank is full, it typically starts to back up in the shower. Some have found that if you thoroughly back-flush the tanks after dumping, and also occasionally drive without emptying the tanks beforehand (to let stuff slosh around), the sensors can stay cleaner and work better.
    ALL GOOD EXCEPT ONE THING.
    Your comment about Tank chemicals is WAY OFF. Tank chemicals do a variety of things.
    1. Break down the solids and help dissolve the tissue
    2. Help keep the tank cleaner and SMELL better. That way your RV does not smell like a Outhouse every time you flush.
    3,. AND HELP KEEP THOSE PESKY TANK PROBES CLEANER SO THEY WILL READ CORRECTLY.
    4. When you dump the tanks, there is nothing nastier/smellier than dumping a Black tank that has NOT had chemicals in it.
    5. They do make a Gray water tank chemical which helps break down the soaps and oils from the kitchen sink. Also, Gray tanks can smell very bad also, so using chemical in the Gray is a good idea also. Doug
  • Welcome to RV.Net, every coach since 1976 that I ever owned had two tanks: Black Tank that your toilet or toilets drain into and a Gray Tank that your sinks and shower drain into. There are meters inside the coach that show the different levels of waste or water inside your tanks (it will show you if your tanks are empty, 1/4 full, 1/2 full, 3/4 full or full) You empty them from a outside compartment. There will be two T-Type handles one is Black (Black Tank) the other is Gray (Gray Tank), next you hook your sewer hose to the tanks outlet (this is where the Black Tank and the Gray Tank meet and form a Y and drain into one fitting with a sewer coupling on it. The other end of this hose goes into the Campground septic tank. You always drain your Black Tank first, when it's empty then open your Gray Tank and your gray water will push all the material that is left in the hose from the Black Tank into the Septic Tank. You can drain your tanks daily or wait until there full it's your choice. Any variety store Walmart etc. will sell chemicals I buy the type that has no formaldehyde in it enviromentaly safe. If your dry camping (no water or sewer to connect) like out in the desert I have gone up too 2 weeks before (2-adults) dumping my tanks and yes there are companies that will bring water to you and come and pump out your septic for a cost. I hope I explained this to you so you will be able to understand? Also after emptying my Black tank and the outside handle is in the close position I use 1/4 cup of Dawn dish soap with 5 gallons of water and when I'm driving down the road it's slushing inside the tank and keeping the bottom of the tank clean.Good Luck.
  • RoyB's avatar
    RoyB
    Explorer III
    If you want to delete what you said in the other post about plumbing just go to edit and delete everything you said and rename the title to OOPS or something like that.
    Another thing you can do is notify the Moderator listed in the forum to delete your entry...
    Roy ken
    NOTE: I just noticed it is already CLOSED so it will be going away soon...
  • I don't think you need to be so concerned about the plumbing system vs other systems on an RV, but my thoughts below in red.
  • RoyB's avatar
    RoyB
    Explorer III
    This is typical water flow diagram for the Rv trailers.
