CharlesinGA
May 30, 2016Explorer
Is this some kind of large manual disconnect on the batteries? If so, it is most likely something someone added to the vehicle to use for winter storage. It would allow a portable battery charger to be connected to the batteries without taking cables off.
Most relays/solenoids for the house batteries are mounted away from the batteries (corrosion and all of that stuff) and is controlled usually by a switch near the door where you can reach in and turn it on before you enter, or off after you step down from the coach.
Charles
Charles
38,776 PostsLatest Activity: May 14, 2026
