SCVJeff
May 31, 2016Explorer
thestoloffs wrote:All of the above is accurate except #1. When hooked up in a CG you need to leave the batteries On. There are very few, if any converters that deliver clean enough power without the buffering of the battery bank that they were designed to be on the output. Problems anywhere from dim lights to massive hum on the radio, to the TV pre-amp not working, all the way to wiping out the fridge control board among others. When camping or traveling there is really no reason to shut it off. That is a storage mode.Cooncatz wrote:
The house battery in the Class-C I recently bought was discharged and I am about to replace it - I have no knowledge of how the switch in the battery compartment works
I assume OFF totally disconnects the house battery from all 12 volt applications.
1. Should I turn the switch off when connected to shore power?
2. Will house battery charge with switch in the OFF position?
3. Should I turn the switch OFF when traveling?
4. Should I turn the switch OFF when RV is not in use?
5. Is the house battery used to start the generator?
Every unit could be wired differently, but most follow certain general principles. On this basis, I'd answer:
- Yes, although it could limit house battery recharging from the convertor.
- See above.
- NO. An absorbtion refrigerator must have 12 VDC power during non-AC powered operation, in addition to gas.
- That's a question of whether or not your unit has parasitic drains (always-on DC items, like LP gas and CO detectors).
- In most cases, Yes. I wouldn't shut off the 12 VDC during generator operation.
(Edit: iPhone auto-correct)
38,774 PostsLatest Activity: May 13, 2026
