- steveownbyExplorer
smlranger wrote:
Absolutely best replacement topper material is available from Stone Vos in Brooksville, FL.
Many folks also recommend Tough Tops for slide topper replacement.
Regardless of where you get the material, it is not hard to R & R. As noted, you need a couple of good ladders and a second person if the toppers are long. There are a number of You Tube videos showing the process.
X2 on Stone Vos. Chris is the owner and is a fellow coach owner. He is really a perfectionist and only uses the best fabric and thread. Call him with your topper measurements & he will give you a price. - ncrowleyExplorer IIWe purchased new slide toppers from "Tough Top Awnings" and used the YouTube videos from RV Geeks. The slide toppers were heavier than the original ones and they work very well.
- TNGW1500SEExplorerYoutube it. It's easy.
- EffyExplorer III have replaced my electric awning fabric once, but if I understand correctly the slide toppers are under spring tension which is a whole different ballgame. I am told it's a DIY project but I have also heard the tension can be a little dangerous.
- crassterExplorer IIAbsolutely something you can do. :) I've never taken any of my coaches in. All depends on health/abilities to do stuff like this. If you are handy, you can probably do it.
- lj2654ExplorerI would think any marine canvas shop could make you up new covers if you take the old one in.
timjet, I would take it off and have a canvas shop stitch it over the tear. - timjetExplorerAlong the same lines, I've got under contract a used coach with one topper that has a slight tear about 1" long on the seam. Can I patch this so the tear doesn't get worse?
- rgatijnet1Explorer III
imgoin4it wrote:
A friend removed the fabric from his toppers, took them to a shop that had sunbrella fabric and had them duplicated. He then installed the new ones. Said he saved a lot of money over typical toppers
That is exactly what I did. A local shop ordered the fabric and sewed it to match the fabric I took out. Total cost for my long topper fabric was $110. This took about 2 hours for me to change out since I replaced the springs at the same time. - imgoin4itExplorerA friend removed the fabric from his toppers, took them to a shop that had sunbrella fabric and had them duplicated. He then installed the new ones. Said he saved a lot of money over typical toppers
- larry_cadExplorer III have changed several slide toppers by myself. It's about an hour long job as long as you understand how the mechanism works and the precautions necessary. My wife goes to the fabric store and buys some canvas fabric, sews it up and on it goes. About $20.
38,777 PostsLatest Activity: May 20, 2026
