Yellowboat_
Dec 11, 2013Explorer
brandonrv wrote:
so I am going to go with an aqua magic style II from an aqua magic V. Is the connection different on the 2?
For my replacement the connections were the same.
Where the water connected was different. The Aqua Magic II water connection is higher up on the toilet. I had slack in my water line but I was still about an inch short of making the connection. I had the high profile Aqua Magic V and replaced with another high profile toilet. I can't say for sure but you may have enough hose to reach the connection on a low profile toilet.
Or, if you install a shut off valve you can add length to you hose or just replace the hose as I did.
Safe travels.
JD
38,769 PostsLatest Activity: Apr 03, 2026
