hotjag1
Mar 30, 2019Explorer II
Ralph Cramden...I've always had really good luck with this fridge as it consistently maintains temps in the mid 30's until the outside temps are in the high 80's to 90, then the fridge temp will rise to 40. It has been around 80 to 82 for several days in AZ and the fridge stayed in the 30's until yesterday. It then moved up to 44 and then 46.
The thermistor clip has been cracked for quite awhile and then broke completely off when I was adjusting it. With no thermistor attached the refer is staying around 34 to 36 when the outside temp is 80 degrees so it appears that Tiffin installed it correctly and the fans are doing their job properly. Knock on wood:)
38,771 PostsLatest Activity: Apr 13, 2026
