Matt_Colie
Jul 08, 2020Explorer II
Randster,
By now you should have figured out that there is no simple good answer to your question.
First, there are a few questions that you have to answer (honestly):
*Do you plan to enjoy the journey?
*Is the rig comfortable to sit in?
*Is the rig comfortable to drive?
*Will there be only one driver?
*Do you plan to use non-campgrounds for overnights?
So,
*If you plan to enjoy the journey, then you need to plan to take your time and look up interesting stops along the way. This can add a lot of time to the travel, but also add immeasurably to the memories.
*If the driver's seat is not long term comfortable, while this can be changed, being less than comfortable can wear you down.
*If the rig is not a one finger drive and requires constant attention, then how comfortable the seat is does not matter, you can only maintain that attention lever for a given period.
*If you have two drivers, the days travel can be greatly extended. If you have a driver and a navigator, this can also unload the effort of driving to a great extent. Just having someone to bring you a beverage on demand is a great advantage.
*If you will only do overnight stops at a campground, you had best add in the time to get to the campground and in your slip to the day's travel. There are huge variables available here.
This is all from a guy that has logged more that a few 1000+ miles days even some in recent years. We travel now in an antique motorhome that is very comfortable and can co-drive if the situation requires, but we try to avoid Bonzi runs as they are not something one can enjoy.
At one time, I was draging a competition sailboat all over the country. The truck was not comfortable and neither was the excursion. I did, however, learn the value of planning. Things are easier if you have at least an idea where you are stopping and when.
On these boards, you will find RVers that are 2-2-2 people. If this is your plan, then it can work for you. These are usually full-timers that -Travel 200 miles -Are at the campground at 2pm -Stay there for 2 days. If you don't have anywhere to be, that is just fine.
What you really have to do is work a few excursions and find out what you are comfortable with doing. The one big caution here is that driving tired is a very good way to end up dead.
Matt
So,
Matt
