65CrewCabPW
Jun 23, 2008Explorer
clockwork oranjaboom wrote:
My '76 w/727 trany has the sensor-type dipstick as well. I can't find an idiot light for it anywhere, but upon close inspection I could make out a 'full' line just above the oval slot at the tip of the dipstick where the sensor is located. Mine also leaks if I park driver's side low.
Hope this helps,
dave
The seals around the shafts that are operated by the shift and kickdown levers are leaking.
The job isn't real hard, but you do have to pull the valve body to do it. That leak is common on every old Torqueflight, but unless it gets serious, you can mostly ignore it.
38,705 PostsLatest Activity: Jan 24, 2025
