time2roll
Aug 15, 2019Nomad
If you expect 120vac power without running the generator you will need an inverter.
If you have an inverter it will operate fine up to its rating and until the battery is dead.
What you need is a voltmeter to better track the charge level on your battery.
The 12 Volt Side of Life
38,763 PostsLatest Activity: Dec 05, 2025
