Ivylog
May 29, 2017Explorer III
The simplest way is to mount a standard dual 120V outlet next to your 120V circuit breaker panel...break the tabs that connect the two sections together. Removed the wires going to the second AC from the circuit breaker panel and attached a 2' male three prong power cord to it so you can plug it into the new outlet. Run short wires from the panel to one of the outlets and a long cord from the other to the outside that you plug into the CG pedestal outlet when needed. Plug the short power cord into which half of the outlet you want it to run off of.
38,766 PostsLatest Activity: Jan 10, 2026
