supercubExplorerApr 24, 2018How to check brake pad on a Freightliner DP ?How do you visually check the brake pads on a 2004 Freightliner diesel pusher Freightliner Chassis? Approximately what is the minimal thickness of pad thickness? I haven't looked, but I believe I h...Show More
Tyler0215ExplorerApr 24, 2018The only way to check drum brakes is to pull the wheel off and then pull the drum off and measure the thickness of the shoe.
Related Content2003 newmar freightliner speedometer stopped workingFreightliner chassisFreightliner OdometerTravel Trailer VIN CheckFreightliner service
