richmond
Sep 02, 2013Explorer
You can use a spot remover/carpet cleaner in a spray bottle but DO NOT soak it. The brown colour likely comes from getting the luan plywood backing very wet, a very common occurrence when the RV seams/roofs develop a leak.
Spot Shot spray has worked well for me, removing the brown stain and cleaning. Spray on, let soak a bit, blot off using a paper towel or a small carpet cleaner with suction.
Heh heh, this roof material is often referred to as "mouse fur"!!!
http://carpetcleaning.urbanquote.com.au/carpet-cleaning/ten-easy-carpet-cleaning-tips/
38,783 PostsLatest Activity: Sep 22, 2026
