carringb
Jul 27, 2014Explorer
walkabout1997 wrote:
My chassis is a 1997 ford e350 cutaway dually.
The E350 is capable of up to 12,300 GVWR. Ford actually had a bulletin allowing final stage upfitters to uprate the GVWR, and many did.
I would recommend re-weighing. The max RAWR is for that chassis is 7,800 pounds and FAWR is 4,600 pounds. If you are under those numbers, I wouldn't worry too much about it, other that maybe consider upgrading to the max spring rate, which is really the only substantial change between the various axle weight ratings.
38,769 PostsLatest Activity: Apr 04, 2026
