lacofdfireman's avatar
Feb 18, 2014
How to dump fresh water on my Class A
So we bought a "Used" new to us Georgetown 351DS Bunk model and am wondering how to drain the Fresh Water. In my last RV it had a Handle just like the Black and Gray tanks that you pull and it would just dump it all. You could pull it and drive home and it would be empty by the time you get home. On this particular Motorhome all I see is a low point drain. When I open it a tiny bit of water will trickle out and then stop. Our fresh tank is full so I know it can't be this. Unless you have to run the pump in conjuction with the low point drain being open. If you do that water sprays out. Just not sure if this is the way to do it or not? I scooted around underneath on a creeper and couldn't find any other drains so I sure it has something to do with the low point drain. Just confused cause our last one you didn't have to run the water pump to drain it. I don't want to mess something up like if the pump is on and no water is coming out do I have to shut it off immediately so I don't harm the pump? Any help appreciated..
  • "The water holding tank has a relief valve at the end of the tank and this drains through a pipe through the floor at out the bottom."
    Ditto for my Rambler
  • Suggest you try to obtain Owner and Service Manuals on-line, or from a local dealer or the Manufacturer.
    Used RV parts suppliers may have them in their inventory.
  • Greyghost wrote:
    Plus it's very inconsiderate of the drivers behind you.
    X2! Got stuck behind a toyhauler draining his tank "on the go" coming home yesterday. Why not just drain it when you get home? Oh, I see....you don't want water everywhere. Yeah, neither do we.
  • lacofdfireman wrote:
    Mowermech was right on. Mine was in the same compartment as the Propane. I have a 1" plastic pipe that is the low point drain and right next to it is another 1" plastic pipe not labeled. I undid the screw cap on this pipe and low and behold it started draining. I'm pretty sure that was what it is for. Thanks for all your help..
    Glad you got it sorted out! ...
  • On our '02 GT325, there's a valve on a line from the bottom of the potable tank with a tube that runs outside under the back bumper. Open the valve, and the tank drains out. No need to give it air to refill that tank and break a vacuum.
    Until I opened up the screwed-shut cupboard doors under the bedroom wardrobes, I didn't find that valve.
  • Our valve is in the same location under the wardrobe, but in our MH there is one door secured and the second door opens to provide access to the valve and the water pump. I do the winterizing from this point as I use the water pump to circulate the antifreeze throughout the lines.
    JM2CW
  • in reference to driving down the road with drain valve open, a crazy Calif Vehicle Code section came to mind. The 2 things a vehicle can "drop" on a highway are water and chicken feathers. look it up if you want.
  • Greyghost wrote:
    In some states, driving down the road with any liquid running out of the RV could result in being pulled over and ticketed!
    In CA you can dump fresh water or chicken feathers leagally. Don't laugh it is the law.
