2_Beagles's avatar
2_Beagles
How to get an RV up a steep drive way
I am considering purchasing a new Thor Quantum 25'. I'll need to back it up my driveway that looks like this:
Actually, it's not that bad. It's a smooth rise of about 6 feet. I can get my 24' Winnebago up now with about a one inch clearance, but the Thor Quantum is definitely lower to the ground. I'll need to raise it a little bit so the low spot on the bottom doesn't hit the rise in the driveway.
Do you know of a not-to-weird method to tweak the RV to make this happen?
Thanks for your ideas.
Joe
  • Use this to post pictures....
    http://photoposting.is-great.net/?i=3
  • gbopp wrote:
    You might try putting boards on the driveway to get enough lift.
    Do you have option of driving in at an angle? That could make a difference.
    My thoughts exactly. You need to reduce the initial change in elevation at the beginning. Angling if possible helps. Air bags only give a few inches, maybe. Can you post a photo.
  • You might try putting boards on the driveway to get enough lift.
  • I would take the new rv and try it before i bought it,,You mite try Air Bags. My 30 footer used to clear my driveway at 1 in .but with Airbags i now have 6 in more.i can keep the tow bar on and its off the ground at 18 in.
  • Oops! The image didn't work. It's more like this:
