D.E.Bishop wrote:
The info you have received so far is pretty much accurate, however, if it were me I would start by going to the following site and downloading the manual #888, Kwikee Manual #888.
Chris Bryant also has it on his site I believe.  Now you have the trouble shooting instructions and a schematic of the electrical.
The fuse for my controller was installed by Fleetwood and not in a (in my case)a Chevy panel.  It is, however, marked step fuse and comes directly off the battery.  There are two fuses and I forget where the other fuse is located.  I'm not in my MoHo so I don't have my wiring diagrams.
I will tell you up front, I don't think there is a blown fuse, if there was your steps wouldn't work.  With the manual in hand and a test light or a DMM you should be in great shape for finding the problem.
As suggested, the override switch may be near the door, then again like mine, it may be on the dash.
"I will tell you up front, I don't think there is a blown fuse, if there was your steps wouldn't work. With the manual in hand and a test light or a DMM you should be in great shape for finding the problem".
Did you READ my post?  There are 2 fuses and the extend step fuse is separate from the step operation fuse. If the Extend step fuse is blown the step will still operate, depending on the year model of the step. Regardless of year model, if the 5 amp fuse is blown and door is closed, it will ALWAYS retract when the ignition is ON. He needs to verify the WHITE wire at the step connections underneath. BEFORE he does anything else. The 5 amp step fuse is NEVER connected to the chassis fuse block on almost all motorhomes. Doug
I Should have explained the difference over the years  The old(more than 10 years ago) the WHITE wire when no 12 volt power the steps stayed extended. The newer, when the WHITE wire HAS 12 volt power the steps stay extended. That is the reason you look for that 5 amp fuse.
