- tderonneExplorerI've been seeing a lot of these lately:
Not cheap, but maybe an idea starter. - tropical36Explorer
HoneyHush wrote:
Go to local metal (industrial supply) house and buy four feet of the next size up square tubing. Cut a little less than a foot from each post and use pins (as mentioned above) to raise and lower.
My thoughts exactly..... - cbshoestringExplorer II
- HoneyHushExplorerGo to local metal (industrial supply) house and buy four feet of the next size up square tubing. Cut a little less than a foot from each post and use pins (as mentioned above) to raise and lower.
:) - rockylarsonExplorerYou can google that: How to Lower Golf Cart Roof.
- sprintmod1ExplorerFlat tires will help for a few inches! :-)
- IAMICHABODExplorer III
- Executive45Explorer IIISawzall.....Dennis
- EffyExplorer IIMaybe some sort of tube within a tube setup with pins and holes to raise and lower? Or a way to completely remove the roof and attach back on when you want?
38,776 PostsLatest Activity: Mar 24, 2025
