Thunder_MountaiExplorer IIMar 18, 2017How to manually/by pass raise power lift bed?First major failure on our Journey, and its out of warranty. Went to raise bed and all I get is a faint click. Pulled the controller access panel and red LED is flashing nine times which indicates "Ha...Show More
TinstarExplorerMar 18, 2017HERE is a thread in another forum that addresses the same issue you are having. Hopefully one of the suggestions will help you fix yours.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringDomestic powered awning - raise outer edgeNewbie power question12 Volt Power Issue
