jeffwhite's avatar
jeffwhite
How to read a digital multimeter, to measure batteries
I have a "Sperry DM-210A" digital multimeter and I'm trying to measure the voltage of my RV batteries.I'm trying to measure the voltage on a 6volt battery (golf cart battery) and a 12V deep cycle battery. When I use the meter, it has 2 different number settings for voltage, some are red with a wavy line above it, and some are Black with a solid lineand dotted line under it (above the V). What's the difference? I used the Black (solid line with dotted lines)V setting at 20, and meaured the battery (12V) at like 1696 (no dots, like 16.96) and the other 12V at 1987. The 2 6V batteries are coming in at around half that. I get that the 6V are 1/2, but don't get the numbers?
  • 2112's avatar
    2112
    Explorer II
    garry1p wrote:
    The internal meter battery is used for the display and ohm setting only. If the display looks good the meter should be good to go for battery testing.
    The meter uses the internal battery to generate a reference voltage. If the battery is too weak the reference will be low, causing a higher than realistic reading.
    Replace the battery and retest.
    Not true.
    Replace the meter battery. If you get the same results, you have a bad meter or perhaps bad leads.
  • When using the meter for checking battery voltage.
    On the meter.
    1. The red lead plugs into the ohm/V (red) hole closest to black hole on the meter.
    2. The black lead plugs into black (COM or neg) hole.
    3. Set the dial position on DVC 20 (Black solid line is DC Volts).
    4. Place the red lead on the + (pos) side of the battery and the black lead on the - (neg)side of the battery.
    5. Meter display should read 12.6 or higher for a fully charged battery.
    To test the meter rotate the dial to the lowest ohm setting the meter should display "1". Now touch the red and black lead tips together the meter should read "0". If it reads anything higher the leads may be bad, the internal battery is low or meter is defective.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yup the wavey line (it is a SINE wave by the way) Is for AC
    NOTE... On your six volts leave the pair in series. IGNORE the jumper except when cleaning or changing batteries.. Treat the pair EXACTLY as though they are a 12 volt battery. for that is what they become when the jumper is installed.
    Also remember the voltage charges.. NO current in or out of the battery for like 30 minutes or an hour before measureing.
  • DrewE's avatar
    DrewE
    Explorer III
    The red wavy line ranges are for AC voltage; the black dash/dotted line ranges are for DC voltage. Those symbols (the wave and the dash above dots) are quite common.
    It sounds like you're applying the multimeter properly, but it's not giving you reasonable readings. (The decimal points typically would be turned on and off by the control knob setting, so that part wouldn't bother me too much.) There are a few easy things to check as to why it's malfunctioning: first, maybe the battery in the meter needs replacement. Second, if that's not the problem, it might be possible to disassemble the unit and clean the big switch on the front; sometimes they're pretty easy to take apart, being a few metal contact fingers on the knob and some arcs of traces on the PCB underneath, and cleaning them might restore proper function. Third, if the readings are consistently offset from reality, it may be possible to calibrate the meter against a suitable calibration source if it has some sort of a calibration adjustment internally. That, of course, is assuming that it's working otherwise.
    I might also check that the leads and jacks are sound and making good connections. You can check the leads by shorting them on the lowest 200? resistance range; they should read at most a fraction of an ohm. That test, of course, assumes the meter is somewhat accurately metering.
