bigred1cav's avatar
bigred1cav
How to replace old dog house tv with flat screen
http://www.freedomrvaz.com/console/watermark_large.php?src=94028
Above is a photo of what the tv looks like. I no not how to make photo appear.
Thanks
  • Johno02 wrote:
    Here is how I did it in a 99 hurricane
    New Flat Screen
    Thanks, but mine is on a elevator that is not built in dash. It holds only the TV and when TV comes out the top wooden tray is gone with the TV?
  • You could look into a ceiling mount where the TV flips flat against the ceiling when driving and swings down when it is in use.
  • FWIW... there was a similar setup in my 2000 Hurricane 30q, and the previous owner removed the tube TV and filled the hole with a plywood frame covered with a material to match the dash. It had a flat front to which he attached a 24 in flat screen TV. Keep in mind the new flat screens weigh next to nothing so you don't need a permanent mounted TV. Just a place to set it when you want to watch tv. So you could fill the hole and then just place a tv in the location once parked. It could ride on the couch or bed while in transit.
