- Phil___StephieExplorerWe did Velcro strips. Tried the small bumper pads, but they would come off since the surface wasn't flat, so they didn't adhere well.
- et2ExplorerKeep the outside lower or higher than the inside. The Velcro thing sounds promising.
- CbonesExplorerMine have what looks like the non sticky part of Velcro circular pads stuck on the aluminum bar where it would hit the window frame. These came from fleetwood when delivered.
- rgatijnet1Explorer IIIGo to Home Depot or Lowes and you can buy a bunch of the self adhesive rubber plugs used to stop cabinet doors from slamming against the cabinet frame. Stick these to the part that rubs against the window frame and your problem is solved permanently. These are very inexpensive and if the surface is clean, they will stick for years. They are available in different colors and even clear.
- EffyExplorer IIon my day night shades I put a strip of soft Velcro on the window frame, and a piece of the loop side on the blind. No only is it quiet, it stays where I want it. Not sure if it will work on MCD. Maybe at least the soft side without the hook side??
- robatthelakeExplorerI clipped a Bag Clip thingy from a Dollar Store to mine . It is like an oversized clothes pin. The shade still moves but isn't as annoying!
38,705 PostsLatest Activity: Jan 22, 2025
