- IamSilerExplorerNo. I thought it was supposed to run on the voltage from the engine but it says no AC so it’s running on LP. I can turn the main light switch off but as I said it turns the fridge off too.
- way2rollTrailblazer
IamSiler wrote:
Haha. Did that and if you turn the main switch off it turns off the fridge too. Need the fridge to run.
Ok, I'll bite again. Are you hitting the battery disconnect switch? - IamSilerExplorerHaha. Did that and if you turn the main switch off it turns off the fridge too. Need the fridge to run.
- way2rollTrailblazerTry the light switch. Sorry I couldn't resist but if this is in fact a legitimate post, the lights work just like the lights in your house. You hit a switch.
What's odd about your post is that you must have figured out a way to turn them on, unless you bought it with all the lights on and have remained that way since.
Again, if this post is legit, good luck. There's lots more complicated in RV's than turning the lights off.
38,764 PostsLatest Activity: Dec 23, 2025
