boogie_4wheel
Nov 18, 2015Explorer
Purchase (or go to Home Depot and get the parts to make your own) adapter for city water connection to your air compressor hose.
Adjust compressor regulator to ~45psi.
Drain and bypass water heater. If no bypass, then drain and install plug/anode.
Hook up compressor to adapter on trailer.
Work your way through the trailer, starting at your guess of the farthest away shower/faucet/sink/toilet/sprayer and run till no more water comes out.
Open low point drains and blow till no water.
Remove compressor, open all faucets.
Remove water heater drain/anode (if you didn't have a bypass) to drain newly acquired volume of water.
38,777 PostsLatest Activity: May 24, 2026
