hostage
Aug 07, 2017Explorer
Bruce Brown wrote:hostage wrote:Loving God's Country! wrote:
We have a 2003 Holiday Rambler Neptune pulling a Jeep Wrangler. The hubby is frustrated with the lack of power that it has when we are pulling on to highways and wanted to know if there are any add-ons to boost the power??? We purchased this unit last fall as our first Class A and would like some guidance from the veterans!
a diesel pusher loaded and towing with the 300 Cummins is a dog for sure;; I assume its a ISC?
if it is here a cheap add on that will maybe get you going good enough
http://www.usdieselchips.com/ts-2110301
Not an ISC - as noted above the low torque ISB rated at 275 HP - 600 # tq with the Allison MH2000.
There really isn't much extra available to work with until everything is maxed out.
yes I was strictly going by OP whom said 300 cummins so I said IF its a ISC try this now once I look its a is a ISB 300HP motor
this is what the op needs to buy and install
http://shop.bankspower.com/i-1124-63754-powerpack-bundle-complete-power-system-with-banks-idash-5-inch-monitor-for-use-with-2003-2007-cummins-isb-commonrail-pusher-motorhome-with-allison-2000.html?ref=category:82
Rear-wheel best gains of +85 hp and +203 lb-ft
JUST make sure its the 2003 common rail and not a 2002 engine!!!!!!!!!!
