Fishinghat
Oct 13, 2013Explorer II
Since you didn't see any leakage around the jack, one has to assume the valve on top of the pump is not holding. You should have one valve for each jack. The T handle on the end of the valve should be backed off.
The T handle can be turned in to release pressure to that jack to raise a jack that won't raise due to some electrical or other problem.
