azpete
Oct 16, 2013Explorer
no, that price is for a new basic joystick valve. RAP0367. order a reman one,(depends on whether they have in stock) or send yours in to have it repaired. this way is much cheaper and carries a one year warranty. local shops dont do one year warranties as a rule.
the valve plunger and guide can be replaced, its available in kit form,RAP1635( 4 pieces to a kit.) but you dont get it tested for valve seat failure. the plungers can be moved from one position to another to check out if the problem moves with it. if it does, you can just replace the plunger and guide.
note** replacement of these parts DOES NOT guarantee a fix. only a leak down test will verify if this works.
the only way hwh has a remanufactured part is if one has been replaced under warranty, and the core is returned to hwh. hwh then rebuilds that part and sells it as a reman part. thats why its hard to get reman parts from hwh. if they dont have one in stock, then only new is available. we quote new price when no reman pieces are in stock.
