- I will need to check my manual.
- Pirate1ExplorerNo external leak. This one jack is not holding pressure. The HWH troubleshooting guide says replace the valve but it doesn't say which valve or where it is. Is this internal to the cylinder or what?
- Start by checking the jack closely to see if you can identify where the leak is. I have to replace several hoses that had started leaking around the swedging.
If the jack it self is leaking, contact HWH for a rebuilt one. You will need the numbers off your unit.
38,763 PostsLatest Activity: Dec 05, 2025
