dougrainer
Oct 26, 2016Nomad
Pretty common part. hard to believe even HWH has none. There are 2 versions and both will work. There is the original large solenoid with manual release screw and the newer smaller with a spring loaded release. Both will work. If you check Amazon and E bay, they both have listings for your solenoid. What was your complaint on the system? There are only 2 reasons to replace that solenoid.
1. Jack retracts after extended
2. Jack fails to extend. Doug
38,769 PostsLatest Activity: Apr 04, 2026
