dougrainer
Oct 28, 2016Nomad
SmithRV wrote:drifterpilot wrote:
I need an HWH solenoid RAP0642. This solenoid powers left rear jack on my motorhome. Motorhome is currently at an RV dealership undergoing other repairs. Dealership contacted HWH to order the solenoid. HWH states the solenoid is on backorder and not expected to be available for three weeks. I don't want to wait that long and am trying to locate a solenoid, preferably new, but will take a "used" one.
I plan on contacting local dealerships tomorrow, but thought I would post a query here with the possibility that someone might know where I could locate a solenoid quickly.
Thanks
Wow same thing happened to us. The solenoid was going bad and told us low battery warning on the HWH control panel. But we have a 1997 Winnebago Grand Tour Vectra 35WQ. When we got it the rear left jack would not go up when we pressed store button and would remain down. Ended begging a bent jack and had to replace it. But the rear solenoid should be behind the battery compartment where you plug in your engine heater to the plug. And we ordered it off amazon. The best way to find where it is lookup your HWH manual and find the diagram and it should tell you either there, online or in the RV's manual. Be careful when replacing and disconnect your battery's hot line. Those solenoids convert 110 DC. Learned that the hard way. If you have more questions message me and I'll help you more.
1. HWH HYDRAULIC Jack solenoids, all 4 are located side by side on the HWH pump
2. They do NOT convert anything. They are 12 volt DC operated from the RV's 12 volt system
3. The ONLY thing I can think of you may have if HWH is a Air system where they do locate the air solenoids in a different location usually close to the engine area. Doug
38,769 PostsLatest Activity: Apr 24, 2002
