jdavidsmi
Jun 20, 2016Explorer
HWH 625 auto leveling system
I need some advice. I have a 2004 Fleetwood Terra with the HWH 625 auto leveling system.
while camping this past week i notice one of my jacks had came up off the ground about 3 inches. I dug out the maintenance manual and went through all the checks but one. which is to check the the hydraulic fluid level. The cap is suppose to have a dip stick and the fluid should be about one inch from the completely full level.
I know where the tank is, but what I can't figure out is how to get to it? its mounted on the outside of the frame between the frame and the generator. I can just reach the top of the reservoir over the top of the frame, but not enough to do any work.
any suggestions?
The auto level worked just as it should when we parked, and when we were packing up to come home the auto retract worked as it should.
thanks in advance
David
any suggestions?
thanks in advance
David
