Frosty_s_Mom's avatar
Frosty_s_Mom
HWH fluid is everywhere--how much can we lose?
DH in his rush to get the rig packed and out of Dodge, pushed two chaise lounges into the basement under the bedroom slide despite the fact that is where the cables and HWH power rod pushes out the slide. yes, it's been some time since he did that. we are now parked again and looking for stuff, noticed my broom and rake had also been shoved in there. scares me to mess with anything hydraulic. thinking I'd pull out one of the lounges, discovered the two were locked together and eventually got them pulled out to discover one had all the channels full of hydraulic fluid. good lord!! the slide went out ok. IF it comes back in, am I needlessly worrying about it? how much of this stuff can you lose AND is there is central reservoir that would tell us how much fluid it should have to safely operate? my manuals are the pits...no specifics anywhere. ease my mind--please. (DH says no problem.....uh huh) this is a 2002 FR Windsong, 34'.
  • Also any chance that your husband added fluid to the reservoir during trip preparations? You also cannot add fluid until the slides/jacks are all retracted. I made that mistake one time with hydraulic jacks. When I retracted the jacks, I too had fluid all over everywhere!!!!
    Ed
  • You might have to call the factory to get the location of the reservoir - on our rig, it's right up front, just behind the front "bumper". I've seen some rigs where you get at it through one of the wheel wells.
    Don't even try to open it until you get the jacks retracted - until the jacks are up, the whole HWH system is pressurized. On our rig, the system isn't pressurized when the slide is out, but I wouldn't risk it until the all the slides are back in.
    Good luck.
    al
  • thank you dennis. I just need to know where in the world the reservoir is so I can ck it. i'll nose around the manuals again. tranny fluid, huh? okay. thanks so much. seems we always have to learn things the hard way.
  • Jacks and Slides have to be stowed to check fluid level.
    Check for pump and fluid tank under entry step.
  • Simply check the reservoir for the proper level. If it's low, add some fluid. Most use tranny fluid but check your manual for the correct fluid. Inspect the undercarriage to ensure the chairs etc didn't damage anything. The fluid on the chair had to come from somewhere, your job is to determine from where.....Dennis
