azpete
Jul 05, 2014Explorer
if you are sure that its not a loose wire in the connector plug, check to see if its a solder connection on the circuit board. if thats the problem, maybe you or a local computer shop could repair that.
last resort is to send the box in to hwh and have them check it out. use [email protected] to request a rga tracking number. i would send both the touch panel and the control box.
the operators manual will not give you as much technical info as the service manual. both can be found on the hwh website.
38,782 PostsLatest Activity: Nov 09, 2020
