jimhaz2402 wrote:
WNY-Pat
Thanks for the link. I'll start 'sifting' thru the Troubleshooting section. Got a blurb thru the mail from HWH: "Turn ON system to see if a red light is indicating a jack down. If so, go to the jack & make sure it is retracted. If so, will unplug the WR SW & see what happens & then check the WR SW". I never was good at code! Are they talking about a wiring switch?
Doxie and Doug--I'll look at your 'angles' when we travel next Sat. to LA. Thanks. jim
EACH Jack has a down magnetic switch on top the jack cylinder. IF the jack is inded fully retracted and THAT jack red down light is ON, you unplug that switch on top the jack and the light goes out. VERY RARE for a HWH down switch to fail. There are 3 wires on top the jack if Automatic(computerized) Leveling. the down switch has 2 wires and just unplug it. The other is a single wire pressure switch, do not unplug it. I am a HWH factory trained tech and I also am confused by the WR. It obviously refers to the Down switch, but what WR means, HWH will have to explain. They may have meant to write WS which is what the switch is called--- Warning Switch. Doug
