- DachristianmanExploreroh well. No more time to troubleshoot. That technical manual site looks promising, but I'm off to go camping. Thanks anyhow.
Tom - DachristianmanExplorerDisplay panel lights up showing my front being low (which it is). I push the up button, and the "jacks extended" light on the dash comes on, but then goes out as soon as I let off the button. If I push any of the "up" buttons, nothing happens, motor doesn't run. Only when I push the down buttons does the motor(s) run. I'll check out the Technical Manual link in the post above.
Tom - mtrumpetExplorerPerhaps there may be something here that will help with trouble shooting..
HWH Technical manuals - Which system of HWH do you have?
Does the display panel light up? - DachristianmanExplorerSlide is opening and closing normally.
- harold1946ExplorerWith the reservoir a quart low I would agree there may be air in the system. Cycle the slide and jacks several times each to purge the system, then top off the fluid again.
- lj2654ExplorerIs the slide opening and closing normally? If not then possibly air in system.
- DachristianmanExplorerI retracted the slide, but the jacks still won't go down. I checked the fluid....it was a little low, so I added about a quart. Still nothing. Jacks won't extend.
Tom - harold1946ExplorerRetract the slide and then try extending the jacks. If the jacks work it indicates low hydraulic oil.
38,750 PostsLatest Activity: Sep 12, 2025
