Jesse_C wrote:
jlrobison
Thanks for the reply, that number is for one of the 2 sources.
Tom N
The problem with the one of the solenoids is with the needle valve assembly (I suspect) Jack is slow going down and up and sometimes will not retract without a little help. Checked the coil resistance and the voltage to the coil, both are okay.
You can remove the solenoid, then unscrew the needle valve. Soak the assembly in a solvent, blow everything out and reassemble.
HWH sent me rebuilt ones. I then send my old ones back for credit.
Download the service info from hwhcorp.com Great info in the manuals.
-Tom
