kohlerguy
Aug 06, 2014Explorer
HWH levelers
Have HWH 625 levelers on a 05 Newmar Dutch Star. On my return trip from Az I noticed the back jack indicators lights came on while going down the road. Now the back jacks have not gone compeletly ...
Gjac wrote:dougrainer wrote:Doug you have described many times how these seals go bad and need to be replaced. What actually happens, do the seals swell causing a tight condition preventing full retraction? What are the seals made from that cause this condition? Is there a different seal material that you know of that can be used to prevent this swelling if that is what is causing this problem? This seems to be more of a problem with the newer HWH systems I don't see this amount of posts on the older joy stick models. Where different seals used, or more clearance between the shaft and seals?Mandalay Parr wrote:
Also may need to lube the cylinder shaft.
ANY lube is a band aid for the real problem. HWH jacks are immersed in ATF when retracted. Lubing will help for a few weeks and then the seals still cause the problem. Doug
