kohlerguy's avatar
kohlerguy
HWH levelers
Have HWH 625 levelers on a 05 Newmar Dutch Star. On my return trip from Az I noticed the back jack indicators lights came on while going down the road. Now the back jacks have not gone compeletly up since I bought it a year ago and have not had the red indicator lights come on til lately. We have taken some short trips and everything is good until we are down the road a few miles. I've checked them when the lights come on and I can see about 4 inches of the cylinder showing which has been normal since purchase. They work fine otherwise. Front ones always to up completely. When I am getting ready for traveling, the control panel is always green in the travel mode.
I'm suspecting they are dropping down just enough to activate the red lights but that's just my opinion.
Will replacing the shuttle valve bring the back jacks up completely?
Any ideas?
  • Mandalay Parr wrote:
    Also may need to lube the cylinder shaft.
    ANY lube is a band aid for the real problem. HWH jacks are immersed in ATF when retracted. Lubing will help for a few weeks and then the seals still cause the problem. Doug
  • I had the same problem with my 2005 Newmar Northern Star. I had all the springs replaced with the new style springs. They have a taper toward the end of the spring were the hook is. I always have my jacks down and haven't had a problem since. Hope this helps.
  • Why do you think you have a bad shuttle valve? You do NOT, but I want to know why you think it is bad. The reason the jacks are not fully retracting is simple. BOTH jack inner upper seals are bad and are not allowing the jacks to fully retract. You should NEVER see any part of the silver inner piston when they are fully retracted. 625 system will not cause the jacks to extend in transit from road heat. The springs are OK if they retract until you get to the 3 to 4 inch mark. The repair is to either rebuild both rear jacks or replace. HWH will rebuild yours, but you must send them in for rebuild which is about 1/2 the cost of new cylinders. Since the jacks are not fully retracted, road heat and engine heat can expand the fluid in the lines and cause the jack cylinders to slightly extend and THAT will cause enough movement to trigger the down switch in each jack. 625 system down switches have MORE play in them than 300/325 systems. You have just been lucky the past year. Doug
  • Check to make sure the return springs are in good shape .They are what holds the jacks in the retracted position.You may have broken ones or missing ones.
