Dave Spurgeon wrote:
Thanks for all the feedback. I've actually been operating this system full-time for 8 years, so I know how to operate it. My understanding is that there is only one solenoid for the front two jacks, so if one is releasing properly, the solenoid is working. This isn't a weak spring issue. The right front jack was not releasing. It is most likely bent, from being overextended, in the Florida Keys, under extremely windy conditions. I got it to release by putting a jack stand under the axle on the front left side, distributing the weight more evenly. I was hoping to here a valve was stuck on that side, but I am afraid it is bent. My fault. I'll never over half way again. By the way, the HWH website recommends WD40 to lubricate the shaft. Again, thanks for all the feedback.
You have a solenoid for EACH jack on a HWH system. POWERGEAR uses 1 solenoid for the front jacks on certain Powergear systems. IF the jack retracts a little, then the solenoid system is working to specs. If you have straight HWH jacks, then there are 2 things that will cause a jack to not fully retract. The springs are weak, but if so, you can push the jack up by hand. IF you cannot push by hand, the INNER cylinder seals are bad and sticking. It makes no difference if you think the jack is bent or the inner seals are bad--The jack has to be rebuilt or replaced. HWH jacks are extremely strong and I have never heard of any HWH jack having a problem from raising one side too much. Bent HWH jacks are extremely rare. In 30 years of working on HWH jacks maybe I have seen 2 or 3 bent HWH jacks. Doug
