The only realistic solution is to replace the hose. Due to the HWH (02 is the hose designation), hose on a slide room the LENGTH (exact) is critical to correct slide room operation. If you can determine which hose it is, there will be a length and AP number on both ends of that hose. That is how you determine the length for replacement. The other posters suggestion is not really feasable as the hose ID is extremely small. The system operates at 3000 psi. You can order the hose direct from HWH and have it shipped to your location. Doug
