dougrainer
Feb 06, 2014Nomad
Pangaea Ron wrote:dougrainer wrote:
The jacks and slides use the same pump and EACH slide by itself will activate the pump to operate the slide. Since it works when you did the jacks and THEN the slides work, you had either a loose connection at the pump assbly, or the pump motor solenoid was sticking. ALWAYS, when you have HWH slides and jacks and ONE system does not operate (slides or jacks) operate the jacks and slides to see if the motor runs. That helps you find out where the problem is. Cold will not affect the slide/jack pump from activating. Cold will affect how fast and smooth the systems operate. I would check the battery and wire connections at the HWH pump motor assbly/solenoids for tightness. Doug
Thanks Doug, you always have good information.
When I operated the levelers, the excess slope light came on, but I was on very level ground. One of the levelers did not activate, which I then forced to work manually. Everything retracted normally, but slowly. Then the slide-outs operated correctly.
I'll check and maintain the electrical connections. That makes sense.
I'll let know how that works out when I can do it without freezing fingers and toes.
Thanks
Excess slope just means 1 or more jacks has reached its maximum extension and cannot extend anymore to level that corner. Doug
38,768 PostsLatest Activity: Nov 21, 2015
