dalecummins
Sep 28, 2016Explorer
I have a 2006 Discovery and my reservoir is on passenger side in rear panel. Its a round tank. It has a plug on top. Plug has a dip stick and there should be 3/4 inch of ATF fluid on the stick. If you have been having a leak in one of the cylinders then your fluid level is below the sensor on side of reservoir. That is why your beeper goes off. Add ATF not hydraulic oil.
38,782 PostsLatest Activity: Sep 10, 2026
