- jtadExplorerThanks Dougrainer.. That's where it was.
- rgatijnet1Explorer IIISince yours is a Monaco product I believe that you retract ALL jacks and then extend ONE jack 5". At that time your jack warning bell may be going off if the fluid level is low. If it is, then you SLOWLY add fluid until the warning bell stops.
If your bell does not start sounding when ONE jack is extended 5-6" than you may already have too much fluid in the reservoir.
The reservoir will be right under your pump. Mine is on the driver's side, front. - howdy35Explorer IIGo to "Kidkasha" post on hydraulic jacks. He has a good picture there.
- If you have the Roadmaster chassis and you have the side mount rear AC condenser behind the Drivers side rear wheels. Open that compartment and unlock the Radiator condenser and it is hinged. Behind that is the Jack reservoir/pump. Doug
- K_CharlesExplorerThe reservoir is hooked to the pump.
- MrWizardModeratorfluid should be checked or added, with ALL JACK retracted
or you will have overflow and a mess when retracting the jacks - wolfe10ExplorerEasier to find if you have someone else deploy the jacks while you walk around the coach.
You WILL hear the electric motor for the jacks when it is running! - msmith1199Explorer II
jtad wrote:
2004 Holiday Rambler Endeavor with hydraulic leveling jacks.. Where the heck is the reservoir?
Follow the hydraulic lines from one of your jacks. On my Tropical the reservoir is in the left rear of the engine compartment accessed by the same door as the air filter.
38,782 PostsLatest Activity: Sep 20, 2026
