rgatijnet1
Feb 06, 2017Explorer III
Since yours is a Monaco product I believe that you retract ALL jacks and then extend ONE jack 5". At that time your jack warning bell may be going off if the fluid level is low. If it is, then you SLOWLY add fluid until the warning bell stops.
If your bell does not start sounding when ONE jack is extended 5-6" than you may already have too much fluid in the reservoir.
The reservoir will be right under your pump. Mine is on the driver's side, front.
38,782 PostsLatest Activity: Aug 11, 2021
